3 members (tclederman, Bill Hanlon, 1 invisible), 197 guests, and 3 robots.
Topics128,106
Posts1,056,213
Members48,436
#419183 06/02/2008 7:54 PM
I
I Offline
The odd time as I disconnect my battery after I run her for a few times a week. The battery cables and connectors get hot. Theres old wiring still but is this an indicator of something besides well,....old wiring?.....lol. Thanx Guys ! Cheerz !
p.s Motomaster Eliminator 875 cca brand new.
jdl Offline
I know that mine get hot after cranking the engine if it doesn't start right away but if it starts right off(or close to it) they stay relatively cool. Could the toastiness be caused by a lot of resistance in the wiring? (PLEASE wait for someone else to chime in, I'm only 13!)
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
You are right about resistance causing heat. It can be be a dirty terminal, a bad connection where the wire is molded into the connector or a bad connection at the starter or ground. Remember that 6 volts pulls twice the amperage as 12 volts and you need thicker cables. I run over the road trucks, and we replace cables if they get warm at all. A failure away from home can be expensive. A dragging starter, that is a starter with worn out bushings, will draw more current. Try to isolate where the heat is coming from.
jdl Offline
Crenwelge, wouldn't his bus be 12v?
Jordan D. Long
Photobucket
If it is a 66 bus, it would be a 12 volt. I assumed it was an older vehicle. However, all of the other things to check hold true for 6 or 12 volt. Our trucks are 12 volt and we use a heat sensor to find weak connections.
jdl Offline
Only reason I asked was because you mentioned 6v.
Jordan D. Long
Photobucket
Jim & Caroline
