7 members (2-Ton, MRMEROTH11, Gdads51, JW51, Shaffer's1950, Southerntruck, 1 invisible), 118 guests, and 1 robot.
Topics128,132
Posts1,056,378
Members48,441
#419015 06/02/2008 5:29 AM
what would the most likely front axle for this truck. it was a air force wrecker in Oregon the rears are Rockwell. the front has square tubes like the Rockwell but i thought the Rockwells had the third member on top. also the axle shafts don't have a u joint in them them are a straight shaft like the rears with something kind of like a gyroscope connected to them under the hubcap to turn the hub
pictures http://community.webshots.com/user/cosmo93
I don't really know.. but at first glance the hubs look like a Coleman hub, so could be that?
Not all Rockwell axles are top loaders, I have seen many Rockwell front axles like yours, not counting the hubs though.
Is there a tag on the inside of the glove box door? if so it should tell you lots if info about the different components of the drive-train.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #419117 06/02/2008 4:31 PM
Apprentice
Apprentice
No idea about the axles, but that is an awesome truck. It screams for an olive drab green paint job.
the tag says the transfer case is a Coleman but it says the axle is F090 but in another spot it says Coleman SD-9 ETC. i was thinking more black and silver but thats only after air conditioning.
Either way it looks like you have Coleman front axle.
Does it give the axle ratio or ratios on the tag?
Grigg
Grigg #419190 06/02/2008 8:04 PM
the rears have a tag that says 7.20 so i think the front is the same
Which rear axles do you have? I have a 62 W5000 NAPCO, it has Rockwell axles, HHDHDX2 for the front-rear and HHRHDX1 for the rear-rear. My front axle looks like it was built with an Eaton center section. Transfer case is a Rockwell. Pics at:
http://rides.webshots.com/album/227086175ErVbWi
Bob
BobS #434497 07/21/2008 3:41 AM
my rear axles are SQHD rockwell 7.20 ratio the t-case is a coleman
