| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | what would the most likely front axle for this truck. it was a air force wrecker in Oregon the rears are Rockwell. the front has square tubes like the Rockwell but i thought the Rockwells had the third member on top. also the axle shafts don't have a u joint in them them are a straight shaft like the rears with something kind of like a gyroscope connected to them under the hubcap to turn the hub pictures http://community.webshots.com/user/cosmo93 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I don't really know.. but at first glance the hubs look like a Coleman hub, so could be that?
Not all Rockwell axles are top loaders, I have seen many Rockwell front axles like yours, not counting the hubs though.
Is there a tag on the inside of the glove box door? if so it should tell you lots if info about the different components of the drive-train.
Grigg | | | | | Joined: Jan 2008 Posts: 33 Apprentice | | Apprentice Joined: Jan 2008 Posts: 33 | No idea about the axles, but that is an awesome truck. It screams for an olive drab green paint job. | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | the tag says the transfer case is a Coleman but it says the axle is F090 but in another spot it says Coleman SD-9 ETC. i was thinking more black and silver but thats only after air conditioning. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Either way it looks like you have Coleman front axle. Does it give the axle ratio or ratios on the tag?
Grigg | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | the rears have a tag that says 7.20 so i think the front is the same | | | | | Joined: Dec 2004 Posts: 10 New Guy | | New Guy Joined: Dec 2004 Posts: 10 | Which rear axles do you have? I have a 62 W5000 NAPCO, it has Rockwell axles, HHDHDX2 for the front-rear and HHRHDX1 for the rear-rear. My front axle looks like it was built with an Eaton center section. Transfer case is a Rockwell. Pics at: http://rides.webshots.com/album/227086175ErVbWiBob | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | my rear axles are SQHD rockwell 7.20 ratio the t-case is a coleman | | |
