2 members (Materman, 55shaker), 68 guests, and 1 robot.
Topics128,079
Posts1,055,941
Members48,430
#416605 05/25/2008 6:30 PM
i have a 1951 GMC panel,i just finished all the body work and paint,i had never taken it for a ride until just yesterday and it was making a poping noise in the drive line<inclosed type of drive line>,iam not sure if the ujoints are doing this or not,but when i put the rearend on a set of jack stands and tried to turn the wheels,the drivers side turn freely but the passinger side will not turn forward and is hard to turn backwards,when i drive the panel it makes this poping sound but the passinger wheel does turn,since its a closed drive line iam not sure what is causing this or where to start,i checked the oil in the rearend and it is full,can someone please tell me what this may be and maybe what i need to do to fix this problen..if i need to call you to speak with you just give me your phone# and i will call,thank you..bob.209-532-8935
gigi #416656 05/26/2008 12:18 AM
Bob, post this in the Engine and Driveline Shop
If I were to take a guess, this problem is why the last owner parked it. Check your u-joints. Did you grease them? If I remember correctly this truck has not been driven in over 15 years. All you are hearing is a popping sound is that correct? No howling of the rear end or transmission? How does it shift? No binding in the shifting? The transmission stays in gear when you drive it? Confirm these questions and then post again in the Engine and Driveline Shop.
GMONIZ #416675 05/26/2008 1:20 AM
OK I WILL GO THERE..BOB
gigi #417123 05/27/2008 10:53 AM
I would start at the passengers side wheel bearing.
sounds like it has given up the farm from what you have described.
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #418972 06/02/2008 4:02 AM
turns out all that was wrong was the emergency brake bolt came loose,also once the u-joint was greased it stop making noise,thanks for yar help.bob
