1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 11 New Guy | | New Guy Joined: Mar 2008 Posts: 11 | i have a 1951 GMC panel,i just finished all the body work and paint,i had never taken it for a ride until just yesterday and it was making a poping noise in the drive line<inclosed type of drive line>,iam not sure if the ujoints are doing this or not,but when i put the rearend on a set of jack stands and tried to turn the wheels,the drivers side turn freely but the passinger side will not turn forward and is hard to turn backwards,when i drive the panel it makes this poping sound but the passinger wheel does turn,since its a closed drive line iam not sure what is causing this or where to start,i checked the oil in the rearend and it is full,can someone please tell me what this may be and maybe what i need to do to fix this problen..if i need to call you to speak with you just give me your phone# and i will call,thank you..bob.209-532-8935 | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Bob, post this in the Engine and Driveline Shop If I were to take a guess, this problem is why the last owner parked it. Check your u-joints. Did you grease them? If I remember correctly this truck has not been driven in over 15 years. All you are hearing is a popping sound is that correct? No howling of the rear end or transmission? How does it shift? No binding in the shifting? The transmission stays in gear when you drive it? Confirm these questions and then post again in the Engine and Driveline Shop. | | | | | Joined: Mar 2008 Posts: 11 New Guy | | New Guy Joined: Mar 2008 Posts: 11 | | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I would start at the passengers side wheel bearing. sounds like it has given up the farm from what you have described. Tim | | | | | Joined: Mar 2008 Posts: 11 New Guy | | New Guy Joined: Mar 2008 Posts: 11 | turns out all that was wrong was the emergency brake bolt came loose,also once the u-joint was greased it stop making noise,thanks for yar help.bob | | |
