| | | Forums66 Topics128,109 Posts1,056,253 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | I have installed the speed bleeders at all four corners and was just thinking if I'm able to just open all the bleeders up and bleed all of them at the same time or do I just need to do each one individually. I've somewhat bled brakes before but didn't know if I could get away with doing all of them at the same time or not since these have the check valve built in. Thanks for the help! Jeremy | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Any air bubble means spongy brakes. I would do one wheel at a time. | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Do them one wheel at a time, then you will be sure all air and old fluid is removed completely between the Master cylinder and that wheel cylinder. Otherwise unequal lengths in the lines, potentialy unequal pressures, you may leave some old fluid or air in your lines, probably the farthest back one. Finally, you can better keep up with the fluid level in your master cylinder making sure it does not run dry and pump more air into your lines goind with one at a time.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | yes, one at a time..start on the passengers rear, then drivers then move up front....repeat....a few times | | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | Does RR, LR, RF, LF bleeding hold true on every vehicle? On my '50 the longest line from the master is the driver's rear because the line to the rear runs down the passenger side. While the right rear cylinder is physically farther away, it is actually on a shorter line than the left/driver's rear. Same is true upfront with the stock lines because the LF line comes from the passenger side again. Wouldn't you bleed it LR, RR, LF, RF? Steve O | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Check your owners/shop manual, I have no idea, of course if someone decides to run a brake line on the drivers side to the rear wheels, it wouldn't be the same. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, the sequence of bleeding is different for different vehicles. The rule-of-thumb is furthest away from the master cylinder is first, progressing to the next furthest, etc, to the closest to the master cylinder.
On big trucks with a hydrovac unit, the sequence is described in the Chevrolet Truck Shop Manual (or GMC Maintenance manual). | | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | Thanks for the help guys!! | | |
