| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | After reading about "Radiator Cap -- Right pressure? " in the big bolts forum now has me wondering what should the pressure rating on my 51, Im running a 350, If Im not mistaken it should be around 15-16 psi but Im not sure...any one know for sure ?
Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | If you're running the original radiator, a high pressure cap will destroy it. It was designed for a 4-lb. cap, I believe. Later models ran a tubular type radiator that will handle much higher pressures than the honeycomb core that was used with the original 6-cylinders.
If you've fitted a modern design radiator, or had yours recored with a tubular type core, the 14 to 16 lb. cap is correct. Otherwise, run a 180 degree thermostat, and plenty of fan, to be sure the temperature stays below 200 degrees at all times, and run a 7-lb. cap, max. Jerry
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Thanks bud, I did buy a new 3 row (Desert) Radiator with the automatic trans cooler build it, so I should run a 14-16 cap ? Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | Sounds right to me! Tubular construction radiators were designed to run a high pressure cap, which is what you've got now. It gives you a lot more safety factor in case you hit a slow traffic jam, have air conditioning, or run a trans cooler, which it sounds like you do. An auto trans can put a LOT of heat load into a radiator, ditto with air conditioning because all the heat from the condenser gets dumped right back onto the radiator. Jerry
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | |
