9 members (Gdads51, jmoore, Danielbolt, JW51, Rusted Nut, 2-Ton, GA Boy, cmayna, 1 invisible),
64
Mod | | | Forums66 Topics128,169 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Bought a short water pump and just saw that the fans bolt pattern doesn't match. The center shaft on the pulley is 5/8" and the center of my fan is about 1". This is for a '58 235. What year fan do i have to buy to match things up. Cecil....... | | | | | Joined: Feb 2003 Posts: 1,379 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,379 | It depends on who you bought the shortened pump from that will determine what fan you need,if its from Jim Carters you will need a fan for a 54 on back and if it came from Patricks you will probably need one from a 55 to 62. The pump from Jim Carters uses a 216 style hub/pulley and the one from patricks uses the 55 to 62 hub and pulley. Jeff | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I think you got it Jeff. I thought they would all be the same. Thanks, Cecil...... | | |
