7 members (klhansen, MNSmith, TUTS 59, Peggy M, Cletus1950, 2-Ton, mick53), 65 guests, and 2 robots.
Topics128,174
Posts1,057,047
Members48,458
Bought a short water pump and just saw that the fans bolt pattern doesn't match. The center shaft on the pulley is 5/8" and the center of my fan is about 1". This is for a '58 235. What year fan do i have to buy to match things up. Cecil.......
It depends on who you bought the shortened pump from that will determine what fan you need,if its from Jim Carters you will need a fan for a 54 on back and if it came from Patricks you will probably need one from a 55 to 62. The pump from Jim Carters uses a 216 style hub/pulley and the one from patricks uses the 55 to 62 hub and pulley. Jeff
I think you got it Jeff. I thought they would all be the same. Thanks, Cecil......
