0 members (),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | For the second time in two months, my carrier bearing has gone out on my '66. This time it has snapped off at the neck where it hangs down. Coincidently the heavy duty bearing on my 65' C20 has gone out at the same time. I purchased a new bearing for the C20 which is of the "half-moon" design (not sure of its true name). My '66 uses the "tear-drop" style but has holes for the larger heavy duty type of carrier bearing on the frame. I cannot find a heavy duty type bearing that fits a '66 C10, only a C20. I don't understand why there are holes but no such bearing that can be used. The shaft of the C10 measures 3cm but the C20 measures 3.5cm. I can only get the larger bearing style in 3.5 not 3. Is there a way to install the heavy duty type of bearing on a C10, or does anyone know where I can find the larger bearing with a 3cm shaft in it. I was thinking GMC 1/2tons used the larger style bearings but I am not sure. Sorry if this is confusing, I will add pictures to try to help. Thanks 1966 C10 1965 C20 | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | Ok, thanks, the link did help. It looks like GMCs had larger drive shafts that would fit the larger size bearing. Looks like I will have to find a larger drive shaft to be able to use it. | | |
