2 members (klhansen, Peggy M),
167
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 45 | The waterpump saga continues. I obviously cannot shorten my water pump shaft until I know which pulley I will be using. LMC sells one for 80 bucks, but that seemed a bit steep for a plain old steel pulley. Does anyone have any idea of which offset pulley would work for a 261, for example, will a pulley of a 72 v8 work, etc., or is the stock LMC pulley the only way to go? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I know for sure a Ford 292 pulley from the fifties will work. I'm sure there are others but I haven't seen where anyone IDed them. You are correct about not cutting until you have the pulley to eyeball in.
A stock one will do you no good. Too long. You need one close to the same diameter as stock. A smaller one will turn the pump too fast. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I pulled one from a Ford truck with a straight six for mine, but I don't remember which model. It fits great, seemed to be out of the late 70's/early 80's. Bolted on, exactly the same diameter as original, and same bolt pattern and center hole diameter, and the right dish. It only cost me $1.
