1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
Apprentice
Apprentice
I'm looking for a steering column for my 1950 Chevy 1/2. I know there are several after market columns but I don't want to spend $500+. I was told 71-74 GM Vans work great buy I'm having problems finding them with tilt, column shift, and no key. Any Ideas what other vehicles have a good set-up (tilt, shift, no key)?
Everything you know is wrong.
1 Offline
I used a column out of a 1980 chevy van with (tilt, shift, no key) worked out great, check out the pictures in my webshots
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Mine is from a '78 Chevy van.
1940 Chevy KC 1/2-Ton
75 chevy van here,shortened 5" on account of dickie do diease.also had the [censored] hole and indicators hole filled............dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
since when is shifter a bad word
1949 Chevrolet 3100
Apprentice
Apprentice
britcon, your truck looks great. The steering column is exactly what I'm looking for. I like that it has the indicator on the column. So it looks like I need to just go check out the GM Vans and find one that I like.
On the 67- 72 Chevytruck Site there is a great Tech tip on this install. A buddy put one in his 53 and it works great. Just make sure to take the column apart and make sure everything is in good shape and tight before you install it will save you time. I did this swap on my 68 and I am very pleased with the column.
Here is the link http://67-72chevytrucks.com/
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
I have a '79 column that's been shortened. I'll eventually get around to removing irgition & filling the hole.
Robert C.
I'm a Genius in the making.
1950 3600
