5 members (Hotrod Lincoln, Chip O, greenie-reddy, rfs56trk, ole green), 89 guests, and 10 robots.
Topics128,077
Posts1,056,013
Members48,433
I'm just finishing up putting together a '58 235 and would like to know what you guys set the valves at. I got Patrick's mild cam with solids. Hot lash is .08 and .18 on stock cam. Patricks son says use stock setting, but gave me a different value. Anyone get his mild cam and setting to use? Or have a cold setting for the stock cam? Cecil........
You Tube
Cecil,
I don't know from nuttin, but there is an old post that spells it out in detail...straight from Patrick's son!
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Board=1&Number=58931&Searchpage=1&Main=9227&Words=%26quot%3Bcold+valve+settings%26quot%3B&topic=0&Search=true#Post58931
Stuart
Thanks Stuart, lot of good info there. Cecil............
