7 members (Gdads51, texas46, Otto Skorzeny, TUTS 59, Ponchogl, klhansen, greenie-reddy),
136
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I'm just finishing up putting together a '58 235 and would like to know what you guys set the valves at. I got Patrick's mild cam with solids. Hot lash is .08 and .18 on stock cam. Patricks son says use stock setting, but gave me a different value. Anyone get his mild cam and setting to use? Or have a cold setting for the stock cam? Cecil........ | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 |
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Cecil,
I don't know from nuttin, but there is an old post that spells it out in detail...straight from Patrick's son!
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Board=1&Number=58931&Searchpage=1&Main=9227&Words=%26quot%3Bcold+valve+settings%26quot%3B&topic=0&Search=true#Post58931
Stuart | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Thanks Stuart, lot of good info there. Cecil............ | | |
