8 members (Bill Hanlon, Jon G, 55shaker, Otto Skorzeny, HandyAndy, UtahYork, DadsFirstPickup, Hotrod Lincoln),
78
Mod | | | Forums66 Topics128,036 Posts1,055,448 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Has anyone on the list made rod or something like that to hold engine compartment hood open on a 41 to 46 chevy truck...I don't think they ever came with anything like that..but being Canadian I used a sawed off piece of hockey stick...ha..ha.. jd
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | actually they did come with a pair, flat bars with a 'notch' in the end that pivot on the ends of the brace rods that attach to the firewall - the latch rod inside the hood side sat in the notch - also had a strap attached so the hood side could be fully folded up without falling against the other side sort of visible here .... mostly the straps are long gone, and frequently the actual flat bars were left off after some repair .... there should also be a rubber cap on the back corner of the hood side so it can be sat against the top of the cowl without scratching the paint, those should be available from the vendors Bill | | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | There is a tech article here with plans to build one, just look through the listings to find it. But what I found I know someone will cringe over this but they work so bear with it. Late 30's early 40's Dodge truck hood prop. Clamps right on Radiator support rods. I can't find paper work right now and can't remember but they came from a Dodge/Chrysler parts shop in the north east. They work great on my '46 Panel.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | These were a GMC item so I've been told, but they fit Chevy just the same. That's my red 46 btw and I copied an original set in stainless, easy deal. I have seen a NOS set 'GM' had all the instructions, so they were available but not many truck owners wanted to shell out the extra $1.25 at the time so they can be hard to find. There are several aftermarket props used on lots of Ford street rods that are being reproduced. | | | | | Joined: Aug 2007 Posts: 11 New Guy | | New Guy Joined: Aug 2007 Posts: 11 | I have found that a golf putter works perfectly,.. at least as a hood suport. It sure as hell never did me any good for golf. Mine has a head cover and a rubber handle so it work muck up the paint.
Dean Sibley Stovebolter Number: 15654 1952 Chevy 3800 Panel Diesel 4X
