4 members (Nick in Manitou, Oswald, MRMEROTH11, 1 invisible), 137 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
#41778 05/25/2003 10:11 PM
When you guys Degrease engines, what methods to you use? I heard steam cleaning it works okay, what about chemicals?
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
When I do mine I use a foaming type degreaser for lighter stuff, otherwise I find a wire brush on the drill works good. Makes the floor a mess but takes off the caked on stuff right off and takes care of the old gaskets too. I also use a putty knife first to get the bulk of the crud off and a flat head screw driver for the hard to reach spots. I just did a F*** 302 today that way and two other 302s like that as well as my 305E. If you are going cheap for cleaners try powder laundry soap with bleach. Cheap and eats grease- just make sure it gets rinsed off or it'll leave a film.
1965 Chevy C-10 Longbed Stepside
I use laquer thinner and regular thinner and kerosene and finish with simple green or one of those orange cleaners and water. I used all kinds of brushes including tooth brushes and paint brushes.
I put my oil changing pan under the engine and catch most of the muck.
54 3100 with 235
62 flatbed dump C60 with 261
