1 members (baldeagle), 89 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#417037 05/27/2008 3:46 AM
Have a 54 235 engine and I am installing a canister oil filter. Which line goes from the filter to the pan, the side outlet or the bottom outlet? I have heard and seen it both ways. I currently have the bottom outlet draining to the pan and the side outlet to the oil pressure fitting.
Saba #417045 05/27/2008 3:55 AM
Funny that you mention it. I thought it was backwards from what others have described with so in Hutchinson KS at the ATHS show this weekend, I paid close attention to new filter kits. They were labeled Inlet on the side and outlet on the bottom which is what I thought was correct. The inlet will go go to oil pressure sending unit area and the outlet will be a gravity drain that goes just above the oil pan rail and drins into the pan.
Thanks for the info, that is the way I have it, bottom draining to pan side to oil pressure unit.
Saba #418186 05/30/2008 12:17 PM
The Chevy truck shop manual:
http://image60.webshots.com/460/1/0/55/2292100550090459121nGskQJ_fs.jpg
Amazing all the stuff you can learn by reading the book! They even have pictures!
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Can't see your pic. It's forbidden.
Craig
