| | | Forums66 Topics128,022 Posts1,055,362 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 15 New Guy | | New Guy Joined: Feb 2007 Posts: 15 | Have a 54 235 engine and I am installing a canister oil filter. Which line goes from the filter to the pan, the side outlet or the bottom outlet? I have heard and seen it both ways. I currently have the bottom outlet draining to the pan and the side outlet to the oil pressure fitting. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Funny that you mention it. I thought it was backwards from what others have described with so in Hutchinson KS at the ATHS show this weekend, I paid close attention to new filter kits. They were labeled Inlet on the side and outlet on the bottom which is what I thought was correct. The inlet will go go to oil pressure sending unit area and the outlet will be a gravity drain that goes just above the oil pan rail and drins into the pan. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 |
| | | | | Joined: Feb 2007 Posts: 15 New Guy | | New Guy Joined: Feb 2007 Posts: 15 | Thanks for the info, that is the way I have it, bottom draining to pan side to oil pressure unit. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Can't see your pic. It's forbidden.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
