| | | Forums66 Topics128,064 Posts1,055,861 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | I'm finally ready to install Fenton headers and exhaust on my '48 daily driver after finishing the bed. I've read some of the posts on the subject, and would like to know if anyone has any good suggestions regarding removal/installation, the best size pipes and type of muffler. I'm looking for that nice sound I've read about. Never done this before, so all tips are welcome. Thanks. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | mtcb; Some folks say Fenton's are a bear to install but I think they're much easier, being in 2 pieces, than a stock exhaust manifold. Here's what I do:
Attach the 2 headers to the block with as few clamps (usually, just one per header) as necessary to hold them on. Turn the clips sideways so they hold the Fenton's on, but allow the intake manifold to slide in too. Then, put the intake on and use those clips on both intake and exhaust manifolds. Then go back and turn the original clips so they hold both manifolds.
You'll get a lot of opinions on which mufflers make the best sound. I used 26" Smitty's, available from Speedway and other vendors. I used 2" pipe all the way back. Sound sweet.
Have you only read about the sound a Stovebolt with duals makes? You're in for a nice surprise!!!
| | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | If you can fit the headers and intake on a "mock-up" head on a bench, you will be a MUCH happier man. Also, do all your fitting and grinding before you coat or paint the headers. I have Patricks dual in dual out muffler and it sounds terrific. Super quiet at idle and wakes up about 2k rpm. I've also heard that 2 straight thru stock truck mufflers sounds good as well. Whatever you use, good luck!!! | | |
