5 members (DennisM, FAST55, G508, 2 invisible),
157
Mod | | | Forums66 Topics128,277 Posts1,058,441 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | I'm updating all of my mechanicals, including Fatman's IFS.
I am leaving the non-essential bodywork and paint for later, and even long term I think I will stick with the "old truck" look.
So I like the "old truck" look of the original column and steering wheel. Anyone re-use these with rack and pinion? I would guess I would have to cut it off the old steering box with my Jet bandsaw and weld on a universal fitting to go to the new rack?
Just thinking at this point.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | R-Bo I plan on the "old truck" look as well however I will use a Ididit tilt for an easier mount to my Heidts front end and power steer. I will choose a steering wheel that looks like the original.
~Jim
| | | | | Joined: Jan 2004 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 70 | I called Ididit a few years ago about an adaptor to make the original steering wheel fit their column, and they said if I sent them the steering wheel they could make an adaptor. | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | I talked to Fatman today. They said you can cut the original, then cut the outer column exposing a few inches of the steering shaft proper, put in a bearing, then weld on a U-joint on the end of the steering shaft. Only have about 4 inches of it sticking out of the firewall, then go modern down to the rack and pinion.
Sounds like how I may go. I can always switch to Ididit or Flaming River columns if I don't like it.
R-Bo
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I got a similar kit from Buffalo Ent. for my 47 Chevy coupe, looks stock with original wheel and 3 on the tree. Uses a rag joint and some other pieces from later model vehicle. He shortened the tube and the shift rod etc. Call Bullalo and see what he can do, 360 652-7684. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I saw one just like you described at a cruise last evening. He shortened the stock column several inches (just stuck through the firewall) welded on a u-joint and had it going to his PS box. He slid the column down some, (steering wheel much closer to the dash). Looked good. | | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | I called Ididit a few years ago about an adaptor to make the original steering wheel fit their column, and they said if I sent them the steering wheel they could make an adaptor. That is exactly what I did with my Pacer front end because I wanted the original steering wheel and column. Worked out well.
1946 Chevy Pickip
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I found quite a nice Old school style column at http://www.limeworkspeedshop.com/ They do some cool column drops as well. If you decide not to use the original, you could give them a shout! Good luck. Jock 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
