0 members (),
75
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Pictures that is! I'm trying to gather up pictures of the back underside of the bed on 1950, 3600's. Any pictures would be welcome. I'm trying to sort out which holes belong and which don't so if I can get enough pictures I can make so comparisons.
Also I would sure like to have a few pictures of the stock 1950 3/4 ton, under bed roller spare carrier. I have quite a few for various years but most are for the 1/2 ton and it is a little different. Thanks your 3600 guys. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | If I had a 3600, I'd share my pictures with ya. I had the same problem on my firewall. Holes everywhere... but not anymore! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well I know you would Bill. Been kinda quiet down that way, did you ever get that VC screwed down good and proper? Are ya gonna have big red ready for the forth of July parades this year? I was kind of hoping to hear from some of the guys with the 3600's but tain't heared a word so far. Denny Graham Sandwich, IL
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Well, I've got a 3600 but I can't be of much use to ya because I don't have my bed installed yet.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | I bet he would still like to compare the holes on your frame to the ones on his. Post a pic. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I'm driving it to Richmond on 7 June for the Virginia Fallen Firefighter Service at RIR. I've cleaned it up, checked all the fluids and driven it enough to believe a 200 mile round trip is possible. It runs great at this point and I'm not sure what can go wrong but I've got a AAA card just incase.
I hope to enjoy the ride and display the truck all in one day. And the 4th of July parade is right around the corner! | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Would you like to have a look-see at my frame? The wrecker bed is attached to the top of the frame, but the other holes may be the same.
Let me know, and I may be able to get the pics later today. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If it’s a stock bed Mobile that’s OK, I just want to see where some of the holes belong in the rear frame cross members and rear panel of the bed. Like what holes belong for the spare tire mounting, etc. Mine has all kinds of extra holes drilled where they mounted hitches and such and I’d like to fill what doesn’t belong when I do the frame and body work. If it’s not to much trouble Dave, yes I would like to see how it looks. It is different than the ’50 but I will add it to my reference album. The details for the ’54 are pretty well documented in the assembly manual although it probably doesn’t show all the holes. Denny G
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | OK - I'll try to crawl under it later this morning and snap off a few images.  | | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | It may take a few days, but I'll try & get you some pics too. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks guys, I appreciate it. Mostly just what you can see sitting behind the truck looking up at the back end. What I'm really interested in is the rear cross sill and first cross member. Denny Graham Sandwich, IL
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | I've got a few pictures right here.< large file size > Let me know if you need any additional angles.  | | | | | Joined: Jun 2007 Posts: 100 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 100 | Does a 49 3800 qualify as needed or helpful? It has a dump bed on it so not sure what holes belong or not.
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor. 1953 2 ton parts truck Long Gone 1957 GMC LCF On 75 Cadillac Eldorado Frame Updated Feb 2021 | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Post 'em. It could even be useful to someone in the future.  | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not sure Ben, but the 1ton might be similar even though the frames are a little different. Of course having the dump means that the cross sill is non-existent but the cross member may be the same. Of you can find the time to take a couple of pic I surely look at them. Hey Dave, thanks, I won't have time to look at the pics this morning, I’ve got a class and then a guitar lesson after lunch but I will definitely look at them this evening. Denny Graham Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Dana but I spent a half hour and never did get past the first page. Those must be monster sized graphics. My dial up conection cant handle high resolution graphics. Denny Graham Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Eric, I got a few pics down loaded before I had to leave this morning. Takes about a half hour to get one thru the phone lines so I couldn't see to much. Tire mount looks different than the Chevy. Denny G
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Denny, I have now pulled my cab and cleaned parts awaiting work out of my bed I will shoot some pictures over the weekend and post them on Monday. Denny check out the 1950 truck pictures at this link! http://www.stlouiscarmuseum.com/inventory.asp
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Will do Brad, I'm not ignoring yous guys, I've just been so dang busy this week I don't have the hours to spend on the confuser like I did in the past. Gonna be real hectic for a month or so and with a dial up connection it takes forever to download graphics. Thanks for all the links and I will get to them in time. Denny G
