2 members (Bill Hanlon, 1 invisible),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I've been putting the interior together and it's coming along. I started buy making a firewall cover out of double sided bubble wrap sandwiched between two layers of jute padding. The floor has jute padding & a tar like sound deadener. I also used the insulation on the rear of the cab and covered it as well. The whole thing was carpeted and it turned out pretty good. BeforeInsulationCarpetRear cabDrivers side
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Nov 2007 Posts: 25 Apprentice | | Apprentice Joined: Nov 2007 Posts: 25 | Just wondering what was the tar like sound deadener you used? im in the process of doin my interior
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Got it here from Classic Chevy Parts.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Man... It's really coming along sweet ! It Looks awesome !  Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Great... you even got me replacing the carpet in the 51 now ! I used this to help block out some of the heat and regular heavy duty padding (donated by the Sahara Casino  ) to help block out the noise. I got some the auto carpet from checkers auto but I didn't like that at all (too cheap) you could see through it it some spots ! So I went to Home Depot and found some real nice indoor/outdoor grey carpet that should work out great. See what you started mobileortho  Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | See what you started mobileortho  Addictive isn't it!!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Never come in here much since my 55's interior is a long way off..but Mobil this looks comfy..very nice! Do your passengers have to take off their shoes to ride in it?
That bubble wrap stuff: what is it generally used for? Also did you use regular carpet or a molded one for your application..
Must be nice to be at that stage..
best of luck with your ride,
Keith | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I'm undecided on the shoes! The bubble wrap is an insulation I found at Lowes. The carpet's not molded. I found it at Orielly's. I was only $11 a roll & it took two rolls to do my floor. I could have chosen more expensive carpet but I'm not building a show truck.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Looks good, I'm a few months away from carpet. I should have the cab interior painted, the underside coated with bedliner, and ready for wiring, gauges, air, and etc..
~Jim
