| | | Forums66 Topics128,057 Posts1,055,815 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 11 New Guy | | New Guy Joined: Dec 2001 Posts: 11 | I am running an eBay auction now for a friend (46 Chev pickup), and a guy wonders what is the difference between a 41 and a 46. I think they are basically the same. Is that true? What should I say? thanks, Garret
1950 Chev 3100 Nevada City, CA
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Garret, First Welcome to the Bolt!!! There are a few differences between the two. There is a ongoing Tech tip here that will help you. Dan | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | id guide for 41 and 46 chevy trucks Here's summary of the major differences for the 1/2 tons
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | The parklamp lenses were longer on the 41 model than the 42-46(not the housings) | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Learned something new today. I owned a '46 and didn't know that.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Go to the Tech Tip tab. There is a new tip there that we are all working on, showing the differences | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | There's something on the tech tip that isn't completly accurate. 'Cause my '45 has 6 boards in the bed. Also my rear fenders has 3 bolts above the fenders and 2 below.
| | | | | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | 5 years....LOL, sorry couldn't resist...  | | |
