| | | Forums66 Topics128,086 Posts1,056,333 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | I have stumbled upon a good '50 GMC 5 window cab and the price is right. Will it bolt on a '51 Chev frame, and if not, what mods or adjustments would I need to make in order to keep it looking like a Chevy, and compatible with the Chevy body? My intent would be to replace the 3 window Chevy cab with the 5 window GMC cab, but still use all the Chevy internal cab components.
shoeless | | | | | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | from what i have seen, everything should work, should be just a bolt in process.
Brian K
*note, someone that knows more, could state some little things that couldnt work, but as a whole, there should be no problem.
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
| | | | | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | shoeless,
i found a nice looking gmc cab as well and from the close inspection that i made, i found no difference between it and the chevy. i really do think it would be a clean cross over | | |
