Brrrr
place holder
2 members (Peggy M, MTD91), 141 guests, and 0 robots.
Topics128,274
Posts1,058,432
Members48,489
#416636 05/25/2008 9:25 PM
I have a 1951 truck down to the frame. It was hit in the right rear at one time. I have managed to take most of the twist out of the rail. It was turned under a bit. When I measure for square to the center crossmember, it is one inch longer corner to corner. From the crossmember to the front, it is only 1/8 inch off. Should I try to straighten this, or should I find someone with a frame rack? I will try to post pictures when I return from my trip later this week.
Thanks for the help.
Ex Hall Monitor
Ex Hall Monitor
There are certain points on the frame that are used to measure it's geometry. For those measurements to be accurate the frame needs to be in a certain relationship to the measuring device. I would recommend taking it to a frame shop if you suspect the frame has been damaged. You might be able to get it close but then again you might not. I've seen a lot of vehicles dog track because of improperly repaired frame damage.
