2 members (Peggy M, MTD91),
141
0
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 166 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 166 | I have a 1951 truck down to the frame. It was hit in the right rear at one time. I have managed to take most of the twist out of the rail. It was turned under a bit. When I measure for square to the center crossmember, it is one inch longer corner to corner. From the crossmember to the front, it is only 1/8 inch off. Should I try to straighten this, or should I find someone with a frame rack? I will try to post pictures when I return from my trip later this week.
Thanks for the help. | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | There are certain points on the frame that are used to measure it's geometry. For those measurements to be accurate the frame needs to be in a certain relationship to the measuring device. I would recommend taking it to a frame shop if you suspect the frame has been damaged. You might be able to get it close but then again you might not. I've seen a lot of vehicles dog track because of improperly repaired frame damage.
