4 members (Bill Hanlon, GMCJammer51, WICruiser, Otto Skorzeny), 116 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
I have stumbled upon a good '50 GMC 5 window cab and the price is right. Will it bolt on a '51 Chev frame, and if not, what mods or adjustments would I need to make in order to keep it looking like a Chevy, and compatible with the Chevy body?
My intent would be to replace the 3 window Chevy cab with the 5 window GMC cab, but still use all the Chevy internal cab components.
shoeless
from what i have seen, everything should work, should be just a bolt in process.
Brian K
*note, someone that knows more, could state some little things that couldnt work, but as a whole, there should be no problem.
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
shoeless,
i found a nice looking gmc cab as well and from the close inspection that i made, i found no difference between it and the chevy. i really do think it would be a clean cross over
