7 members (Gdads51, texas46, Otto Skorzeny, TUTS 59, Ponchogl, klhansen, greenie-reddy),
136
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | HI...we are having one heck of a time trying to figure out what the PO did on our 235/55-57(3837004) with the water pump? I know he cut and moved the radiator housing and the latch panel because this engine is longer than the 1954 model..our pulley looks like a cone it looks like the one off an early Corvette. The fan is attached to the end of this pulley cone. The water pump pulleys we have seen are flat faced??? Our water pump has a long nose on it. It all works and we want to install our new 19" SS flex fan but what the heck did the PO do...why is our pulley in the shape of a cone is it a later model?...frustrated....T/C Steve...
ps..the pulley we have looks like a pulley off a 1963 235..can we keep this set up or do we need something else?
| | | | | Joined: Apr 2004 Posts: 42 Apprentice | | Apprentice Joined: Apr 2004 Posts: 42 | You are a welder if you want you can restore the radiator housing and the latch panel & install a short pump. Or use it as is but the mess the PO made may not cool very well. The pulley you have may be stock off a 216.
Kelly
| | | | | Joined: May 2007 Posts: 46 New Guy | | New Guy Joined: May 2007 Posts: 46 | Can you give us a couple of pics. You can Shorten the later 235/261 water pumps and install the pulley that is available through Patricks. Or you can try to find a pulley from a long water pump small block Chevy. (scarce) If you get Patrick's catalogue it explains how.  Roy
It's easier to get older than it is to get wiser.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It sounds like you have a normal 235 water pump and pulley.
