1 members (Ridgeback),
42
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41608 04/13/2004 9:05 AM | Joined: Oct 2003 Posts: 91 Member | | Member Joined: Oct 2003 Posts: 91 | does anyone know if 1936 chevy 1 1/4 ton body is the same as a 1936 chevy 1/2 ton body | | |
#41609 04/13/2004 9:21 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I seem to recall Ken has experience with this subject. I believe there are low cab and high cab versions.
#41610 04/13/2004 10:55 AM | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | The low cab is the same for both. I don;t know about the high cab, but my guess would be that they were the same as well. | | |
#41611 04/17/2004 12:19 AM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Cabs are all the same for Pick-up/ Big truck...only difference between 1/2 ton & Big Fellow are the front fenders: bigger radius for the 1-1/2 ton (or other models w/ 20" tires)
Now, there are two cab styles for '36:
"High Cab" - Continuation of the '33-'35 Cab: easily identified by THREE hinges on the front door pillar. Entire Cab & Doors are framed-out with wood structure.
"Low Cab" - More rounded cab with TWO hinge doors...only wood are the two front pillars and cross-bar under windshield; no wood in doors.
Either "Style" of cab may be found on 1/2 ton or Big trucks, but all are same size.
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
