5 members (Jon G, Nick in Manitou, TexasJim50, baldeagle, Woogeroo), 67 guests, and 3 robots.
Topics128,014
Posts1,055,332
Members48,419
#41608 04/13/2004 9:05 AM
does anyone know if 1936 chevy 1 1/4 ton body is the same as a 1936 chevy 1/2 ton body
#41609 04/13/2004 9:21 AM
I seem to recall Ken has experience with this subject. I believe there are low cab and high cab versions.
#41610 04/13/2004 10:55 AM
The low cab is the same for both. I don;t know about the high cab, but my guess would be that they were the same as well.
1936 GMC T-14 1/2-Ton Pickup
#41611 04/17/2004 12:19 AM
Cabs are all the same for Pick-up/ Big truck...only difference between 1/2 ton & Big Fellow are the front fenders: bigger radius for the 1-1/2 ton (or other models w/ 20" tires)
Now, there are two cab styles for '36:
"High Cab" - Continuation of the '33-'35 Cab: easily identified by THREE hinges on the front door pillar. Entire Cab & Doors are framed-out with wood structure.
"Low Cab" - More rounded cab with TWO hinge doors...only wood are the two front pillars and cross-bar under windshield; no wood in doors.
Either "Style" of cab may be found on 1/2 ton or Big trucks, but all are same size.
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
