3 members (Danielbolt, bluechev, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41515 01/17/2002 5:17 PM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | As with a lot of vehicles someone chopped out the under floor pedal system and did some unsafe creative mods. under the dash Does anyone have a measurement for the correct location or can tell me what or where to look for in case there are some remnants of the old hook up? | | |
#41516 01/17/2002 5:31 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | The floor pedals were originally attached to the clutch housing, the parking brake bolted to the tranny.I have a 37 pu and a 46 big truck. The pedal assembly looks the same more or less on both. The bigger trucks use a clevis and bell crank from the pedal to the master cylinder.My 37 has the parts modified from a big truck so I cannot say for sure what the smaller trucks use.A guy here had good photos of mounting the pedals to a bracket on the frame if you are using a different clutch housing .Having fun yet? | | |
#41517 01/17/2002 5:53 PM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | '37-'46 1/2-ton pedal assembly bolted to the tranny and bellhousing. Pushrod pushes directly on the master cyl. Similar, but different bracket from the 3-spd. to the 4-spd. Since the 3-spd. is a smaller tranny, the mounting bosses on the pedal bracket extend in farther. 3/4-ton and bigger trucks have a different pedal assembly that was hung off the frame rail and used a bell crank to push on the master cyl. pushrod. | | |
#41518 01/17/2002 6:07 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Barry the pedals on my 46 2 ton are directly bolted to the bellhousing. No frame bracket.The master is mounted on a frame bracket with a bellcrank and rod to the pedal. The pedals in 37 pu were taken right off a 37 1-1/2 ton truck. It has what looks like the exact same arrangement as the 46 truck.I installed the 37 1-1/2 ton set up in the pick up as is worked well with the different master cylinder I used Are we saying the same thing ? | | |
#41519 01/18/2002 3:34 AM | Joined: Jan 2001 Posts: 30 Member | | Member Joined: Jan 2001 Posts: 30 | Get Jim Proffit to email you a pic of his pedals. Even though he changed the trans, the pedals are bolted to the bellhousing and trans in the right place. If that is not enough I can try to find old pic of what my 46 looked like before change.
Tony- I know what you are describing; I think Barry may be referring to the m/c which is on the frame bracket on the larger trucks, but your pedals should be in same location as 1/2 ton even though the brake rod doesn't go directly into the m/c like on 1/2 ton. | | |
#41520 01/18/2002 3:35 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Barry
Unless you have a GMC they come with the bigger trans in the 1/2 ton version Never seen a GMC with the little one | | |
#41521 01/18/2002 4:36 AM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Yep, sorry, I wasn't very clear with that answer. I'll try and explain it better. The 1/2-tons use a frame that gets wider as it goes towards the back. The 3/4 and bigger trucks use rails that run parallel to each other (roughly 36" apart)to make mounting different bodies easier. The 1/2-ton pedal mounting bracket is different from the bigger trucks. 1/2-tons use a cast bracket that bolts to the bellhousing with 3 bolts and the tranny with 2 more bolts. The master bolts right to this bracket. The clutch and brake pedals both pivot off this bracket, but from seperate shafts. The 2 tranny bolt bosses on the 3 spd. bracket extend in farther than on the 4-spd. bracket since the 4-spd. is a larger tranny. The 3/4 and larger trucks have a common shaft for both pedals, and don't use the 1/2-ton bracket. There is one hole in the end of the shaft and a small bracket with 2 more holes to bolt into the bellhousing. These pedals are different from 1/2-ton pedals. Both pedals are bent different from the 1/2-tonners and the brake pedal has ears for the m/c pull-rod that runs to the master bell crank. Clutch pedal still has a hook on the bottom on both. The big truck master bolts to a bracket mounted to the frame.(remember these frame rails are straight, so all the linkage runs parallel to the rails) The 1/2-ton master hangs from the same bracket the pedals are on and doesn't use the bellcrank and linkage, just a pushrod. | | |
#41522 01/18/2002 4:53 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | | | |
#41523 01/19/2002 2:33 AM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | Thanks for all of the information. Since I didn't get the original motor or transmission with Panel I will have to resort to plan B. I know I can buy an after market under the floor system that takes into account the narrowing rails. | | |
