7 members (Otto Skorzeny, MickeyP, Brian Moore, Gdads51, Wayne67vert, Bill Hanlon, 1 invisible),
49
Mod | | | Forums66 Topics128,049 Posts1,055,653 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 10 New Guy | | New Guy Joined: May 2008 Posts: 10 | Well, I picked up a 58 GMC this weekend and am having a bit of a problem with actual identification. The title says it's a 59. OK, not a 58...I can still work with it.
VIN identification on this site says it's a 61 (obviously not a 61)
However, the truck only has single headlights which says that it is a 57 (well, at least the fenders are).
Can you tell me where else to look to actually identify this truck? | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Sounds like someone did some title swapping at one point.I once bought a what was supposed to be a 1956 Ford pickup,according to the title,later on the state police discovered someone had taken a 55 and a 56 truck and made up one to sell. However they used the wrong title. I guess if your VIN plate on the truck says it is a 1961 and the title has that same VIN on it it is legal. Just my guess. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The number cruncher on this site doesn't cover GMCs. Your number should be something like 101 P S1234. 101 means 1/2-ton short bed, P means Pontiac assy. plant, S means '58 or '59, the numbers are the production sequence. Lower numbers would be '58 production. Not sure when the change was. A '57 would have a T. If your single headlights are in '59 fenders, it might be a fleet option truck . Check out Old GMC trucks.com | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Could it be that it was titled in '61? I've heard of people putting the year they titled it on the title. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | My 49 was titled in 1950 and it shows that on the paperwork. The old farmer who bought it originally drove it around the farm before deciding/realizing it had to be registered. | | |
