7 members (Otto Skorzeny, J Lucas, dt235sd, Cosmo, jeffreyguy, Charles in CA, LAROKE),
132
Mod | | | Forums66 Topics128,107 Posts1,056,221 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 27 New Guy | | New Guy Joined: Jun 2003 Posts: 27 | Have a 6v. 1954 Chevy Coupe, 235. I would appreciate your help. When idling the amp meter reads charge/discharge appropriately. When I accelerate RPM the needle begins to wave wildly and I suspect that the system is not charging properly. Seems like I read about this somewhere but I can't find it anywhere now that I'm the one with the problem!
PS - for all of you who helped so much last year when I had carb problems, thanks again. Car has been running beautifully since even gets pretty darn good gas milage.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | revted47,
My unprofessional first guess would be the voltage regulator is on the fritz. The second guess, and a little less likely would be the generator...the brushes could be worn down and bouncing or the commutator could be funky with carbon.
I would have my assistant start and rev the engine to duplicate the problems while I held a hose or some type of listening device on the voltage regulator cover. If this is the problem, you might hear 'ticking' that coincides with the jumping ammeter.
Stuart | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | That's what I would say too, but I'm even more uneducated. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It depends how wild is wildly. My amp meter doesn't have any damping for some reason and it oscillates quite a bit with any stimulus. For example, with the engine off, turning on the ignition is good for a couple of gyrations. Now if the gyrations are say larger than quarter scale and the average position is not where you want it to be, then there is a problem. The regulator constantly switches the generator field in and out and thus supplies a lot of fluctuations in current. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | It's pretty easy to check & clean the points on your voltage regulator. Try that first & see if it smooths out your ammeter.
| | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I had the same problem it ended up being the V-regulator... which are still available... Peter | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I didn't go into that but my voltage points were causing wild fluctuations at one point and I took it apart and filed bothe the current and voltage points. That solved that problem. I left a post about the adjustment phase of the job. | | |
