6 members (Scott '48 2ton, Gray_Ghost, Peggy M, Jon G, Wayne67vert, Jaison), 138 guests, and 3 robots.
Topics128,163
Posts1,056,962
Members48,458
Just about ready to start a Toyota conversion..I have a pump but have purchased nothing else..It occurred to me that the frame is taller on a 3/4 in some areas and I'm questioning if that will affect this installation..Anyone know if the drag link and pitman are the same? That might shed some light on this.
Keith
If you are talking about an AD truck, I believe that the front springs are the same so there is hope!
1951 1 Ton Completed
No 55 second series..
thanks
Keith
I am not absolutely positive, but If I remember correctly, the 1/2 ton parts are smaller. The 3/4 and the one ton may be the same.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
From what I've seen, 1/2-1 ton are the same on the TF trucks. at least every one I've seen matched mine for size.
Bill Burmeister
Thanks Long-
I know the frames are different-3/4 ton is taller-at least in some sections. Not sure if that increases the distance from the hole that the box shaft comes thru to the steering arm . I probably will just have to try it. I'll also aske CPP.
Keith
That shouldn't make a difference, the suspension mounting points are the same, as is the steering geometry. Also, the 3200 1/2 tons use the same chassis as the 3/4, just with lighter axles.
Bill Burmeister
I wasn't trying to say that they aren't longer or shorter, but just that the drag link is of a larger diameter in the 3/4 ton. The pitman arm ( mounts to the steering box) is identical.
It is too many years ( 39 ) since I did this swap to remember, but like Bill says, the geometry doesn't change.
Bob
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
Sounds encouraging..
Thanks guys
Keith
