6 members (walter74, Jay R, 52Carl, Wally / Montana, Hotrod Lincoln, 78buckshot), 122 guests, and 2 robots.
Topics128,089
Posts1,056,417
Members48,443
#41404 08/25/2004 9:45 PM
I just finnished installing a pcv system and eliminating my draft tube on my 51,3100 with a 235,I fabricated a tube to replace the draft tube and purchased a pcv valve and gromet and a four foot piece of 5/16 hose all toll about ten dollars for parts needed. the engine seems smile to run a little quieter,and no more oil drip on the driveway, no more oily smell when engine is running,I will run it this way for a while ,and let you all know how it works out. old navy 51 from new jersey....................
#41405 08/25/2004 10:11 PM
ODSS President
ODSS President
That's the first thing I noticed too, that it was quieter! cool
~ Cosmo
1949 Chevy Half Ton
#41406 08/26/2004 3:26 AM
Sounds like a great deal, can you post a pic or two some time?
#41407 08/26/2004 11:46 PM
I
I Offline
I assume this will work on a 49 216 ci?
No reason not to help the enviornment.
ia49
#41408 08/27/2004 2:17 PM
Wouldn't the open vents on the valve cover on the 216 and the early 54 235 make a pcv work less effectively?
#41409 08/27/2004 2:31 PM
Jake,
On the 216 the vents in the valve cover is where the the system gets its make up air. In thru the cover thru the engine down thru the engine, then out the pvc set up to the intake manifold to be burned.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#41410 08/28/2004 1:28 AM
Will a PCV setup cause a drop in the intake manifold vacuum level?
#41411 08/30/2004 2:56 PM
I heard about a PCV jar. Size of a beer can. The pcv hose goes in the can and passes some nickel balls or selica gel granulat that seperates out the gunk bevor the unburned gases feed back in the engine. I was told it saves a great amount of gas to.
As soon as I solved the heat problem on my 235 I try that out.
Frank
#41412 08/31/2004 1:45 AM
Like this?
PCV jar
and Additional info
*** GMC ***
