| | | Forums66 Topics128,005 Posts1,055,263 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Anyone know if the starter for a big block Chevy is different than for the small block? Thanks
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: May 2007 Posts: 12 New Guy | | New Guy Joined: May 2007 Posts: 12 | the anser to your question is some are the same depends on ring gear tooth count.if both are large flywheel,168 tooth,block mounted with 2 long bolts they should interchange.some older small blocks used a low torque starter that would not be desirable for big block. | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Starterman, Thanks for the git-back. Just got my first big block and the starter is bad. I have one for a small block, but didn't know if they were interchangable. Is there a way I can tell if the one I have will work? Thanks for the help.
| | | | | Joined: May 2007 Posts: 12 New Guy | | New Guy Joined: May 2007 Posts: 12 | pablos49, If the starter mounting looks the same,the high torque starter usually has two leads coming out of the case about 3/4 inch from the end and ataches to the solinoid.If the mounting is the same both low & high torque would start the big block cold,but the low torque may not turn fast enough to start when hot.hope this helps | | | | | Joined: May 2007 Posts: 12 New Guy | | New Guy Joined: May 2007 Posts: 12 | pablos49, If the starter mounting looks the same,the high torque starter usually has two leads coming out of the case about 3/4 inch from the end and ataches to the solinoid.If the mounting is the same both low & high torque would start the big block cold,but the low torque may not turn fast enough to start when hot.hope this helps. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Stetter??? I used the hi torque starter(With the two leads) Can't brag enough how it works, $63 at the Flaps. | | |
