| | | Forums66 Topics128,164 Posts1,056,982 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Just about ready to start a Toyota conversion..I have a pump but have purchased nothing else..It occurred to me that the frame is taller on a 3/4 in some areas and I'm questioning if that will affect this installation..Anyone know if the drag link and pitman are the same? That might shed some light on this.
Keith | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you are talking about an AD truck, I believe that the front springs are the same so there is hope! | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | No 55 second series..
thanks
Keith
| | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | I am not absolutely positive, but If I remember correctly, the 1/2 ton parts are smaller. The 3/4 and the one ton may be the same. Bob
55 Cameo 396 TH 400 with overdrive 65 Caliente conv 67 BB Caliente conv 67 Mercury 1 Ton 76 GMC 3/4 ton 454ci 84 Buick Turbo Regal
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | From what I've seen, 1/2-1 ton are the same on the TF trucks. at least every one I've seen matched mine for size.
Bill Burmeister | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Thanks Long-
I know the frames are different-3/4 ton is taller-at least in some sections. Not sure if that increases the distance from the hole that the box shaft comes thru to the steering arm . I probably will just have to try it. I'll also aske CPP.
Keith | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That shouldn't make a difference, the suspension mounting points are the same, as is the steering geometry. Also, the 3200 1/2 tons use the same chassis as the 3/4, just with lighter axles.
Bill Burmeister | | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | I wasn't trying to say that they aren't longer or shorter, but just that the drag link is of a larger diameter in the 3/4 ton. The pitman arm ( mounts to the steering box) is identical. It is too many years ( 39 ) since I did this swap to remember, but like Bill says, the geometry doesn't change. Bob
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Sounds encouraging..
Thanks guys
Keith | | |
