Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Hotrod Lincoln, baldeagle), 36 guests, and 2 robots.
Topics128,005
Posts1,055,254
Members48,418
#412275 05/12/2008 8:30 PM
I've been reading up on old treads about the hydramatic trans. I'm going to look at a parts truck tomorrow for my 55 1st, and the guy says he thinks it's the original automatic trans,my original plan for my truck was a t-5 swap with my 235, because i wanted to run a little faster, whats the best way for me to go? If i wanted to go a little faster with this?
- Zach Morris
The hydro will not give you any more top end speed, than any other stock trans for your truck. Final gear ratio is one to one. The rear end will have to be upgraded with taller gears or changed to a later model rear end with taller gears. 3.33 to one gears are available for the 55.1 rear axle which will net you more top end than the stock 3.90 gears.
If you get the truck and decide that the hydra-matic must go, let me know. I may be interested in some of the parts and linkage. Thanks, Greg H.
Greg_H #413889 05/18/2008 1:24 AM
Another option would be to add an overdrive. I have an overdrive ( Hone-o-Drive) in my 55 coupled to a Th400. I put this in in 1970, and I have never regretted it. I have run it with gears as high as 4.57 and still got good gas mileage. I am presently running 3.73 gears.
Those Hydramatics are an excellent strong transmission.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
The Hydro has a really low first gear, so another option would be to change the rearend to something like a 3.08, then you don't need an overdrive but you will be able to get off the line just fine.
Paint & Body Shop moderator
The hydra-matic is a 4 speed auto. It has as mentioned a real short first gear. They do not use a torque converter rather than a torque coupler. They actually have 100% efficiency where a modern auto has between 5 and 10% slippage. That is the reason for the low first gear. You can push start a hydra-matic where you can't a modern auto trans. The shifts are firm and crisp. There is no park. You start the truck in Neutral and park in in reverese which has a locking pawl when there is no fluid pressure. They are not for everyone but I enjoy the one in my truck.
Greg_H #414172 05/18/2008 8:13 PM
Just to add to Greg_H's posting for general knowledge. I believe all the truck Hydramatics had the forward and rear pump which enabled push starting, but some of the later car transmissions only had the front pump. (The rear pump was driven by the output shaft ) It isn't a big deal as long as you know that you have the original transmission in the truck, but the newer transmission could be damaged by attempting a push start. ( Not to mention the fact that it wouldn't start).
Bob
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
hey bigblockcameo, do you have any pics of your 55 ?
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
What do you want to see in the pictures? I have a '55 1st GMC 1-ton with a Hydra Matic. I found mine in a barn and it still has the patina it showed that first day.
