11 members (Jay R, Gdads51, Wayne67vert, 68ironhead, baldeagle, 3B, JW51, walter74, Jon G, carbking, 1 invisible),
44
Mod | | | Forums66 Topics128,004 Posts1,055,247 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 33 | I've been reading up on old treads about the hydramatic trans. I'm going to look at a parts truck tomorrow for my 55 1st, and the guy says he thinks it's the original automatic trans,my original plan for my truck was a t-5 swap with my 235, because i wanted to run a little faster, whats the best way for me to go? If i wanted to go a little faster with this?
- Zach Morris
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | The hydro will not give you any more top end speed, than any other stock trans for your truck. Final gear ratio is one to one. The rear end will have to be upgraded with taller gears or changed to a later model rear end with taller gears. 3.33 to one gears are available for the 55.1 rear axle which will net you more top end than the stock 3.90 gears. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | If you get the truck and decide that the hydra-matic must go, let me know. I may be interested in some of the parts and linkage. Thanks, Greg H. | | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | Another option would be to add an overdrive. I have an overdrive ( Hone-o-Drive) in my 55 coupled to a Th400. I put this in in 1970, and I have never regretted it. I have run it with gears as high as 4.57 and still got good gas mileage. I am presently running 3.73 gears. Those Hydramatics are an excellent strong transmission. Bob
55 Cameo 396 TH 400 with overdrive 65 Caliente conv 67 BB Caliente conv 67 Mercury 1 Ton 76 GMC 3/4 ton 454ci 84 Buick Turbo Regal
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The Hydro has a really low first gear, so another option would be to change the rearend to something like a 3.08, then you don't need an overdrive but you will be able to get off the line just fine.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | The hydra-matic is a 4 speed auto. It has as mentioned a real short first gear. They do not use a torque converter rather than a torque coupler. They actually have 100% efficiency where a modern auto has between 5 and 10% slippage. That is the reason for the low first gear. You can push start a hydra-matic where you can't a modern auto trans. The shifts are firm and crisp. There is no park. You start the truck in Neutral and park in in reverese which has a locking pawl when there is no fluid pressure. They are not for everyone but I enjoy the one in my truck. | | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | Just to add to Greg_H's posting for general knowledge. I believe all the truck Hydramatics had the forward and rear pump which enabled push starting, but some of the later car transmissions only had the front pump. (The rear pump was driven by the output shaft ) It isn't a big deal as long as you know that you have the original transmission in the truck, but the newer transmission could be damaged by attempting a push start. ( Not to mention the fact that it wouldn't start). Bob
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | hey bigblockcameo, do you have any pics of your 55 ? leonard | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | What do you want to see in the pictures? I have a '55 1st GMC 1-ton with a Hydra Matic. I found mine in a barn and it still has the patina it showed that first day.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
