8 members (Donf, Gdads51, 55shaker, FAST55, Ponchogl, Wickedbass, Cosmo, Hanks custodian), 66 guests, and 5 robots.
Topics128,065
Posts1,055,868
Members48,428
#41380 03/18/2005 6:22 PM
The origional manual for my '40 GMC pickup says to use "Steerin gear Lubricant" in my steering box. I cant find any spec's on this. What would be the modern equivelent be? Thanks, G. Lee
#41381 03/18/2005 9:29 PM
PENRITE Steering Box Lube.
http://www.penrite.com.au
#41382 03/18/2005 10:03 PM
You can use chassis grease in these old steering gears w/o any harm at all. I have used it for years. It even helps to seal them.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#41383 03/18/2005 10:51 PM
Chassis lube works fine, was even recommended as a substitute by GM. I prefer a moly base, it works better at low temps. And yes, if your box leaks, it's better than stop-leak. grin
Fred
52 3600
69 C-10
#41384 03/19/2005 2:36 AM
I've been using Lucas gear lube additive as a top-up in my diffs,manual steering boxes,and older transmissions for quite a while now.Kinda pours like warm honey.(20% in the engine) Our 64 Comet 170-6 has 100,000 mi. on the rebuild...200,000 on the car.It has worked fine all round for me.Does it do all it claims? Don't know.
65 C10 292/700R4 long fleet...Gettin closer by the day.
#41385 03/19/2005 1:22 PM
Thanks, it had regular old grease in it when I dismantled it. I think I will go with that. Once again thanks everyone. G. Lee
#41386 03/21/2005 1:14 AM
I use SNAPPER gear lube (00 weight), It is thicker than gear oil and not as thick as chassis grease
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
#41387 03/21/2005 2:43 AM
Penrite is top-o-line, but some folks suggest using STP oil treatment straight out of the can/container
#41388 03/21/2005 4:06 PM
I've used the Snapper gear lube or marine lower end grease. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
