7 members (Cosmo, baldeagle, Paul_WNC, Bill Hanlon, gswbbc, HandyAndy, 1 invisible), 174 guests, and 2 robots.
Topics128,040
Posts1,055,478
Members48,424
#413354 05/16/2008 2:50 AM
hope this is in the right spot,didnt know where else to put it. i got a 12 bolt from a 74 1/2 ton in my 49.when i tore the brakes apart yrs.ago i had a buddy bead blast the small parts,then stuck them in a ziplock bag.i've since bought a new hardware kit that has the springs and things like that in it but i will have to use a few of the old bigger pieces.should i paint these pieces or just coat them with wd-40 to prevent rust.i'm talkin like the e-brake arm,self adjusters,things like that.would like yur opinions........dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
they came unpainted factory, but i don't see where painting them will hurt anything. Just make sure to keep the paint off the threads for the adjuster, coat that part with a light coating of anti-sieze or brake lube so it won't rust up. Same for any pivot or contact point in the brake system.
Bill Burmeister
LONGBOX55 #413587 05/16/2008 11:35 PM
I would not want WD-40 or other oil based stuff near my brakes. I'd rattle can the bare steel. Plated self-adjusters are usually pretty inexpensive at FLAPS, but still use anti-seize on the threads.
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
primer paint them and store away
Jim & Caroline
I've read that primer with no top coat invites rust. I'm moving this to paint shop so the pros can chime in.
Cletis #413641 05/17/2008 3:12 AM
cletis,
I think it depends on the primer - epoxy (or urethane) primer will seal the surface will not allow rust to develop.
The primer would have to carefully and thoroughly scuffed-up if it sits for longer than the recommended time before adding any additional surface coats/preparations or top coats.
Tim
I
I Offline
Tremclad Paint. Spray Can. Problem solved.
never heard of it what is it..............dave
1949 Chevrolet 3100
the Canadian version of Rustoleum, same company now, prolly same paint
Flxible #419161 06/02/2008 6:57 PM
I
I Offline
I used it on my bus interior for the floor and everywhere else. The finish is amazing. I used High Gloss and the paint still looks wet !
