Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (baldeagle, CuzzFuzz), 27 guests, and 0 robots.
Topics128,003
Posts1,055,245
Members48,418
#413307 05/16/2008 12:26 AM
Anyone know if the starter for a big block Chevy is different than for the small block? Thanks
My truck: She may not be the prettiest girl at the dance, but she's all mine!
pablos49 #413315 05/16/2008 12:56 AM
the anser to your question is some are the same depends on ring gear tooth count.if both are large flywheel,168 tooth,block mounted with 2 long bolts they should interchange.some older small blocks used a low torque starter that would not be desirable for big block.
starterman99 #413340 05/16/2008 1:44 AM
Starterman,
Thanks for the git-back. Just got my first big block and the starter is bad. I have one for a small block, but didn't know if they were interchangable. Is there a way I can tell if the one I have will work? Thanks for the help.
pablos49 #413502 05/16/2008 5:10 PM
pablos49,
If the starter mounting looks the same,the high torque starter usually has two leads coming out of the case about 3/4 inch from the end and ataches to the solinoid.If the mounting is the same both low & high torque would start the big block cold,but the low torque may not turn fast enough to start when hot.hope this helps
pablos49 #413503 05/16/2008 5:11 PM
pablos49,
If the starter mounting looks the same,the high torque starter usually has two leads coming out of the case about 3/4 inch from the end and ataches to the solinoid.If the mounting is the same both low & high torque would start the big block cold,but the low torque may not turn fast enough to start when hot.hope this helps.
starterman99 #414008 05/18/2008 1:28 PM
Stetter???
I used the hi torque starter(With the two leads) Can't brag enough how it works, $63 at the Flaps.
