Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (cmayna, Barney1951, Jaison, 1 invisible), 42 guests, and 5 robots.
Topics128,010
Posts1,055,305
Members48,419
#413222 05/15/2008 4:39 PM
Im starting to repair my dash which is really rusty. i dont want to pull out the gauges and stuff so i though i would use a sander and not a blaster, i was wondering which set up i should go with. another thing im going to blast the rest of the inside cab because it to is rusty and was wondering how should i cover up the gauges and windows, im not going to blast anywhere near them i just dont want to risk breaking them somehow.
chevyguy45 #413228 05/15/2008 5:48 PM
Take it apart - gauges, glass, dash bezels and knobs.
It sounds like you've already made your mind up to use a blaster. So go the extra step and protect what you have.
Besides, what are you going to do after your done blasting? You have to paint it anyway.
Just my 2 cents.
HC
57' Chevy 3100 Stepside
http://www.cardomain.com/ride/2630531
Heavy-Chevy #413250 05/15/2008 7:58 PM
I'd use the blaster on both the dash and the rest of the cab, and would take the time to take it all apart as Heavy said...
I totally disassembled mine, sandblasted it really good repainted and it looks super...
You can try to cut corners by hand sanding or masking things without removing them, but often won't get as good of a result or may damage something and have to replace it if you don't do it right the first time so that's the direction I'd go...
Just my $0.02...
~Trev
TrevsOldChevs #413261 05/15/2008 8:51 PM
yah I think i will just pull it all apart, i havent looked to hard but do the knobs just pull off, and how do you disconnect the gauges?
chevyguy45 #413345 05/16/2008 2:01 AM
Depends on the dash, but they're usually VERY simple to figure out if you look at the gauges on the rear of the dash...
On the '37 two bolts hold each gauge in... doesn't get simpler than that! wink
~Trev
TrevsOldChevs #413358 05/16/2008 3:00 AM
Well, lets see. . .
I would start by pulling the steering wheel smile
Seriously, though. If you're not completely prepared to dismantle everything you see in the cab (be it with the right tools - steering wheel puller - $20). I’d stop now and assess what needs to be done and what you’re willing to do.
Most jobs I plan on doing usually take twice as long as I plan (that’s just me).
The knobs come off differently on each control (at least on my ’57 they do). . .
Let see if I can recall some (don’t hold me to this though)
Headlights – there’s a release button on top of the body under the dash.
Some knobs (choke and Throttle) – set screw
Windshield – threaded (I think)
Take your time and I’m sure it’ll turn out looking great.
Any questions check back here – There’s bound to be an answer with these guy’s/gals.
Heavy-Chevy #413805 05/17/2008 8:05 PM
What year are we talking about, and what condition is the wiring behind the dash in? If it a ’45 and the wiring is original I’d pull the dash and start replacing the wiring. Both pulling the dash and the wiring job are pretty straight forward.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
chevyguy45 #413903 05/18/2008 2:02 AM
sand blast it mine was so crusty i covered the guages with cardboard and tape and in about 15 minutes saved myself hours of work that wouldnt have cleaned up as good anyother way no more rust you can also just sand blast the areas you want
Moderated by  ndkid275, Phak1
