| | | Forums66 Topics128,121 Posts1,056,328 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I have looked in alot of catalogs but cannot find any hold down bolts.
Does anyone reproduce the battery hold down bolt? | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Have you checked the J.C. Whitney catalog ? I believe they still have them.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Feb 2004 Posts: 29,807 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,807 | I use a piece of all-thread, and bend a hook into one end by heating it with a torch. For a more stock-appearing one, use non-threaded rod and break out the tap & die set. Thread a short section of the top, and bend the bottom to fit your application. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Lonnie, The bolts on all my '54 battery trays were attached with two heavy rivets per bolt. I used threaded stainless steel rod as described by Jerry but a I ground the threads off on two sides at the bottom of the rod, drilled holes in the flat metal, and attached the rods to the tray with flat-capped machine screws (so they looked like rivets from the outside). You could do the same with long bolts, buy cutting the heads off; grinding the non-threaded "base" flat; and, then attach each bolt to the tray. Hooked bolts (as described by Jerry) were used from 1955 onwards (J-bolts). Or, replace the whole battery-tray assembly (which includes the bolts). Tim | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Thanks for the comments.
Lonnie | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Deka makes a variety of battery hold down bolts. These are available at any of the FLAPS or online http://www.northernautoparts.com/ProductDetail.cfm?ProductId=2853Otherwise a welder, some rod stock and the tap and die set. Scott
