4 members (TooMany2count, tclederman, Gray_Ghost, 1 invisible), 93 guests, and 0 robots.
Topics128,132
Posts1,056,386
Members48,441
#413049 05/15/2008 12:09 AM
I have looked in alot of catalogs but cannot find any hold down bolts.
Does anyone reproduce the battery hold down bolt?
Have you checked the J.C. Whitney catalog ? I believe they still have them.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
I use a piece of all-thread, and bend a hook into one end by heating it with a torch. For a more stock-appearing one, use non-threaded rod and break out the tap & die set. Thread a short section of the top, and bend the bottom to fit your application.
Lonnie,
The bolts on all my '54 battery trays were attached with two heavy rivets per bolt. I used threaded stainless steel rod as described by Jerry but a I ground the threads off on two sides at the bottom of the rod, drilled holes in the flat metal, and attached the rods to the tray with flat-capped machine screws (so they looked like rivets from the outside). You could do the same with long bolts, buy cutting the heads off; grinding the non-threaded "base" flat; and, then attach each bolt to the tray.
Hooked bolts (as described by Jerry) were used from 1955 onwards (J-bolts).
Or, replace the whole battery-tray assembly (which includes the bolts).
Tim
Thanks for the comments.
Lonnie
Deka makes a variety of battery hold down bolts. These are available at any of the FLAPS or online
http://www.northernautoparts.com/ProductDetail.cfm?ProductId=2853
Otherwise a welder, some rod stock and the tap and die set.
Scott
