3 members (Lightholder's Dad, 2-Ton, TooMany2count), 83 guests, and 3 robots.
Topics128,024
Posts1,055,393
Members48,422
Can anyone identify this GM number off my starter - 1107[0]45 -
Serial No 1D[2]6. The brackets are for numbers that are obliterated on the data tag and are my best guess.
I've been through the master parts book and all the online resources I can find and I can't identify what year(s) this can be used on. I got it at a swap meet and I am hoping it will be usable on my 54 235. Any help would be appreciated
Still trying to get ole Betsy back on the road.
jdl Offline
If you had a picture I could(or anyone else here for that matter) could tell you. I don't know about the numbers though.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Right now its all in pieces but in a day or too I will have it back together if I don't run into any problems. I don't know how it get a picture to the forum yet but I'll work on that too.
If you have a standard you need a 1112389, a 1112396 if you have a power glide but other numbers will also fit. beginning with 110 doesn't sound right. As far as I know everything that would possibly fit begins with 111.
1107 are the first 4 digits for a number of Delco Remy starters.
I can't tell you the application but 1107245 when put into this decoder at the Delco Remy site comes out as 10461597 as the remanufactured/replacement for the old number. (No other substitution for the 5th digit in your 1107x45 number yields a result.)
http://www.delcoremy.com/PartNumberRef.aspx
After further searching of the Delco Remy site, I found starter 10461597 referenced on p 128 under 10MT-HT Series and a picture of that series core on p. 75.
http://www.delcoremy.com/LiteratureDownload/Documents/Core%20ID%20Guide.pdf
If this looks like your starter maybe 1107245 is the correct number and you are closer to your answer.
Hope this helps.
Last edited by randy luton; 05/15/2008 11:55 PM. Reason: further research on part number
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
