0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Can anyone identify this GM number off my starter - 1107[0]45 - Serial No 1D[2]6. The brackets are for numbers that are obliterated on the data tag and are my best guess. I've been through the master parts book and all the online resources I can find and I can't identify what year(s) this can be used on. I got it at a swap meet and I am hoping it will be usable on my 54 235. Any help would be appreciated
Still trying to get ole Betsy back on the road.
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | If you had a picture I could(or anyone else here for that matter) could tell you. I don't know about the numbers though. | | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Right now its all in pieces but in a day or too I will have it back together if I don't run into any problems. I don't know how it get a picture to the forum yet but I'll work on that too. Thanks
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | If you have a standard you need a 1112389, a 1112396 if you have a power glide but other numbers will also fit. beginning with 110 doesn't sound right. As far as I know everything that would possibly fit begins with 111. | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | 1107 are the first 4 digits for a number of Delco Remy starters. I can't tell you the application but 1107245 when put into this decoder at the Delco Remy site comes out as 10461597 as the remanufactured/replacement for the old number. (No other substitution for the 5th digit in your 1107x45 number yields a result.) http://www.delcoremy.com/PartNumberRef.aspxAfter further searching of the Delco Remy site, I found starter 10461597 referenced on p 128 under 10MT-HT Series and a picture of that series core on p. 75. http://www.delcoremy.com/LiteratureDownload/Documents/Core%20ID%20Guide.pdfIf this looks like your starter maybe 1107245 is the correct number and you are closer to your answer. Hope this helps.
Last edited by randy luton; 05/15/2008 11:55 PM. Reason: further research on part number
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
