0 members (),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 50 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 50 | I have a 52 chevy 1/2 ton, trying to figure out the correct way to install the weatherstripping around the doors, I bought the good seals from Chevy duty, they have a longer leading edge on one side, that I assume protrudes into the cab opening once installed ? But having trouble shutting the doors completely once there. Doors shut fine and flush before with the old seals. so any pictures out there I can see to determine which way they go ? thanks all | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The 90° corner of the seal is glued on both legs into the corner of the door frame, the acute angle or more pointed corner is directly oposite to the 90° corner and pointing outword. Here's a shot of the drivers side seal, and these were from Chevy Duty also last year: http://rides.webshots.com/photo/2535155990098611668OIGypn Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2005 Posts: 50 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 50 | Thanks Denny, yep I put mine on wrong. | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | And give those new seals a few weeks to "set" if you have problems with the doors closing all the way. I had trouble getting mine to close flush, or real close to flush, at first. Kept the doors closed as far as possible for a few weeks with a few tweeks here and there and eventually they did come in.
Bob | | | | | Joined: Sep 2005 Posts: 50 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 50 | Hello Denny, what about the bottom of the door where the metal strip holds a seal, I noticed my door seals were too long, and there is enough to do the bottom of the doors, but it appears it gones on differently ? does the long edge go under the strip ? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just noticed your post Mobil, a picture is worth a thous...... well you know the rest, try this; http://rides.webshots.com/photo/2395785850098611668qDSomp Should be one piece starting at the bottom about 10" from the front and going all the way round till the ends meet. Denny G
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Nov 2008 Posts: 17 New Guy | | New Guy Joined: Nov 2008 Posts: 17 | Many thanks guys.... I had no idea how to put the weatherstrip on my '49 Chevy until this thread.
Thanks.
Harrell Lee Sellers Brookings, SD | | | | | Joined: Nov 2008 Posts: 17 New Guy | | New Guy Joined: Nov 2008 Posts: 17 | P.S. Did you take the door off?
HS | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Was doing a search on this because this is my next endeavor on my 53. Found that most pictures are not linked anymore, especially photobucket and webshots . So I found these two links on you tube showing how to do this job. Got a few hours of research so hopefully this helps someone else in the future. Steve www.youtube.com/watch?v=Rc631QtdiC0 - link no longer valid 1947-55 1st series Chevy Pickup Door Weatherstrip Installation
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
