5 members (Robert Crandall, Danielbolt, Phak1, Bill Hanlon, 1 invisible), 325 guests, and 5 robots.
Topics128,156
Posts1,057,021
Members48,460
Folks,
The holes on my manifold where the heat riser/counter weight thing goes through have worn to a point where they leak bad. What can/should I do.
Much thanks,
Jim
I haven't heard of that before. I would take it to a machine shop and see if they could put bushings in.
1951 1 Ton Completed
Chevs of the 40's sells an oversized heat riser shaft. Just ream the holes to fit, problem solved.
Isn't it a major task to get the counterweight off the old shaft and installed correctly on the new shaft. I actually though the weight was almost part of the original...not removable.
The plate that's inside the manifold would probably take lots of imagination to R&R too. That isn't a friendly environment in there....I sure am a pessimist, huh!
Stuart
I started driving a 50 GMC to school in 58 and been tinkering with them ever since. I think I have 7 of them now. I thought they were supposed to leak. I'm too old to worry about such things now.
mine was stuck..........then i got it loose.....engine ran the same being stuck as it does now working..........should be zero difference in performance if its loose
In my book that sticking, spring actuated, exhaust choking, flap is a hazard and a waste of time to fiddle with. I took the advise of an old timer who worked on the old stove bolts for years. He informed me to slide in a grade #8 bolt through the manifold using flat washers, and double nut the bolt. Don't forget to use "Never seize on the threads. You could also tap and thread the shaft holes and install short bolts, this will cause even less restriction on exhaust flow. Seriously now, if you know and respect your old stove bolt motor, you are going to drive her nicely until you warm her up anyway.
Tim in Ca
[i][/i]
