| | | Forums66 Topics128,018 Posts1,055,341 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41271 01/29/2003 2:56 AM | Joined: Jan 2002 Posts: 7 Member | | Member Joined: Jan 2002 Posts: 7 | Can anyone help me with the vital stats on tuning up my '66 250 c.i. p.u.? You know, points gap, degrees above or below dead center, dwell... I looked all over town for the book and had to order one "on line". I really wanted to tune it this week, and can't wait for the book. Had no luck at the local library, and different parts houses give me different info. | | |
#41272 01/29/2003 6:16 AM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | robber,
'66 Pickemup truck 250c.i.
AC 46-N spark plug @.035 gap
Point Gap: .019 dwell 31-34 degrees
Timing is 6 deg BTDC
Hot idle speed: standard 500 RPM Automatic: 'As low as possible to obtain smooth idle and prevent creep in Drive or harsh shifts.'
Idle speed depends on whether or not you have the A.I.R. (smog pump) system.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
